Volume Increase
Zido
New User
Encountered this problem when calling from the phone app to another app, quiet sound in both directions, version 16.0.9. Tell me how to fix this right now? or where to look for this setting?
Hi!
For incoming audio volume, you need to use the built in Volume Up/Down button of the phone.
For the audio volume you send from the App to the remote party, in the App --> Settings --> Advanced, you can try adjusting the Microphone Gain option.
Additionally, you can also try toggling the option in the "Audio Subsystem API".
These are the options you have.
iOS 14.6 does not have this setting.
"For the audio volume you send from the App to the remote party, in the App --> Settings --> Advanced, you can try adjusting the Microphone Gain option. "
Where can I find these settings?
"Additionally, you can also try toggling the option in the "Audio Subsystem API"."
@Zido
You opened this thread in the "Android" section of the forum.
Are you having this problem on IOS only?
This problem on all devices.
For Android you can try what was mentioned above.
For IOS, unfortunately there is no way to increase the volume of the Microphone.
@Zido
Since you said this issue affects all devices, can you provide us a test account on your PBX to check?
Stephan Eusebe
