Vtiger CRM | Call Report
bastien_alv
Platinum Partner
This thread follows my old thread.
My crm is connected and I have the lookup contact. (it's a Vtiger like)
However, as I was told, it won't work for the call report because it was done for an old version of 3cx.
Do you have an example of how to modify the template to make it work?
What has changed at 3cx to make it no longer work?
Thanks for help
DM me the template, I should be able to fix it for you quite easily.
It's all about the EntityId and EntityType.
Here is the template, can't send it via DM
thx
maxpcc
