W60B w/ 3 Phones in a Ring Group - Busy Signal on 2nd Call
bmilheron96
Hey guys, just started using W60B/W56H for the first time. I have one base and 3 phones on a 2 channel trunk with 2 DIDs. I have incoming calls using the trunk's default destination of ring group 800 pointing to all 3 handsets. First call works fine, but 2nd call results in a busy signal. I assigned their 2nd DID to a separate extension using the 3CX app, and I can have 2 concurrent calls that way, but it seems this base won't accept more than one call despite having 3 phones.
Any suggestions?
If the first ring group still ringing, when the 2nd call comes in. If so this is correct , as the extensions are busy it will go to not available routing,
ring groups can not accept multiply calls
Is this a scenario where a call queue will work better?
Perhaps change the ring strategy, and not use ring all?
Isaac415
