Solved Wallpaper for Fanvil X4G
nvroom
I bought a Fanvil X4G to use with my Enterprise 3CX install, but when I provisioned it, the wallpaper disappeared and now it's just a black screen with a time. Apparently, there's a setting under phone provisioning to add a wallpaper but that box isn't there on my install.
I would really like to change it to something other than a black screen.
Before I provisioned it there was a White FANVIL background - I'd settle for this, but I'd like a custom picture.
You can find the file requirements for each supported phone at https://www.3cx.com/docs/ip-phone-background-logo/
You would then upload/choose the custom background on the phone provisioning tab.
Since I haven't used Fanvil phones I am not sure what the default background is supposed to be.
I just realized you said X4G and not X4U.
What template are you using for that phone? I don't believe X4G is supported.
**EDIT** I mean for custom logos. Link shows X4U but not X4G.
https://www.3cx.com/sip-phones/fanvil-x3-x5/
  • Fanvil X4/ X4G/ X4U
EDIT: Oh LOL.
I can upload a logo on the phone web page but I don't think that sticks after reboot or reprovision
When I pretend to add a phone to my system here is what I see depending on template/model chosen:
Fanvil X4: I don't have the option to set the custom logo
Fanvil X4U: I do have the option to set the custom logo
The logo is overridden by the phone template. That is why it doesn't stay after reboot or re-provision.
On the fanvil site they say this: Screenshot 2021-08-16 204550.png
Can I not just go into the template and edit it to match the x3u?
Hi @nvroom
We will look into it and see if we can add it in our next update to V18.
Since we do not currently set a logo to the X4G, if you add one manually via the phone UI it should stick for now.
The change has been scheduled for V18 U1
Diogo Maia
