Solved webclient MAC no audio
exeviadm
Buenos días,
los clientes que tienen MAC no pueden escuchar ni hablar.
Todas las notificaciones y permisos están activados. La llamada se realiza pero no se oyen los interlocutores.
Hi there.
What do you mean by MAC?
In the screenshot, we can see that it's Windows application.
Yes from web client Mac:
No Audio.
From App Microsoft:
Are you able to have echo test from MacOS by calling *777 and hear your own voice?
I have taken the test and the user of the Mac does not listen to himself
So you basically saying that it does connect you can see it, however no audio right?
That's it. With no user who has MacOs. We have even tried others that are not from the organization. All users with MacOs present us with the same problem
Maybe you can run the wireshark on the MAC directly and see the traffic from the IP of the 3CX on ports 10500-10999.
Do you see UDP packets arriving to the NIC of your OS?
resolved after opening traffic in the Network security Group:
Inbound rules NSG:
Glad to know this is resolved ;)
Jake_Southern
