Solved WebClient Not showing as an Option
bentech
Platinum Partner
Hi All,
I think I am missing something but I have a 3CX instance on AWS for one of my clients and in the WebClient it does not give the option to answer calls using the webclient in chrome. I don't want the plugin, I just want to answer from the website. It only gives me the drop-down for the actual phone. Any ideas?
Do you have Enable Web Client / Browser Extension Checked? Extensions General Tab
Yup. Checked that.
Do you have the browser extension installed?
I installed the browser extension and still nothing. Any other ideas?
Is WebRTC enabled in Settings -> General -> Allow WebRTC.
Also, are you in HTTP or HTTPS?
Allow WebRTC did it. Thanks. Thought that was enabled by default.
EMMEPICASA
