WebClient
Heath
I am having issues with The WebClient.. When trying to place Call getting an error 'Requested Device Not Found'. Now when there is an incoming call, the Webclient rings, but can't answer it. Get the same error message when I click answer... Now I have 2 PBX hosted remote at 2 different locations, and getting this error on both and on all ext.
Not sure but from your screen shot it looks like the extension is in DND. I'd probably try signing out and then signing back in.
Looking at the screen, you are trying to use the webclient phone,
Have you enabled the option - settings - General - Enable WebRTC softphone in Web Client and associated features (WordPress Plugin and Conference Dial-In integrations)
Reactions: JohnS_3CX
I went into setting and it’s enabled. This is happening on ALL extensions and on both PBX at 2 different locations.
@Heath I receive the same error if I try to use the WebClient while my microphone is disabled.
Is the mic functional in windows?
Yes. It’s the same mic used. Interesting that it will work with the windows app. But not through the web.
@Heath Based on the screenshot you provided it seems that the speakers might be disabled, see10302
This would also cause that same prompt as a disabled microphone.
fransisco
