Welltech 2540 Setup in 3CX
dgallardo
Good Day,
I recently bought a welltech 2540 FXO Gateway, do you have any manuals how to setup the FXO Gateway and how to add it in 3CX?
Sorry, I'm new to PBX Systems.
I have some few questions.
  • Where does the Main Trunk No comes? can i generate this?
  • I have a direct phone lines, does the DID no. have some formats like i need to add the country code + area code as well?
Thank You
The trunk is the Gateway in 3CX that you create, it will assign it a number (normally starting from 10000).
I think as far as the line goes (and im not 100% of this) it purely depends where you are located and what the provider presents. I am in the UK and we don't normally have to alter anything.
My suggestion is to set the gateway up, make a couple of calls and see what is presented.
Okay, thanks for your assistance, ill try things on my end.
megalmazan
