What’s the recommended MAX limit for hosted?
Input IT
I’m in the middle of pricing up a 3CX from system for a multi academy trust consisting of 15 schools
I am thinking of hosting it with 3CX and each school will have a SBC connected to it
In total there will be around 5000 users and 800 handsets
Is this too much for a hosted instance?
someone told me many years ago I should aim for a PBX for such a setup, I have installed an on premise PBX for a similar sized MAT before and it works great until the schools on-site network technicians fiddle with the network switches
Any advice would be appreciated
32 channel should be more then enough, the MAT i have now has only ever peaked at 18 SC over the past year - I am more concerned about call quality with a hosted system over onpremise PBX
Big like this I would manage it yourself but host it in a cloud provider like AWS or Google. Hosted is great but if you need to upgrade at some point, it's easier. (Hosted stops at 32SC.)
I wrote this yesterday but it apparently didn’t post:
5000 users is off the chart of https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/. Besides calls, the phones/apps/BLF updates all hit the server.
Re: call quality, on premises or hosted, voice is going over the local Internet connection either way. If these schools are in different locations it’s all dependent on Internet anyway.
Edit: thought maybe I should expand a bit...5000 users would normally be around 1600 calls at a 1:3 ratio. 20 calls would be almost no usage, but each usage case is different. Have to find what works but I would not be expecting a "small" spec server to work well with 5000 extensions.
Jeremy Hofex
