What IP's URL's does 3CX require access to to operate correctly.
princer800
Gold Partner
Is there a list of IP's or URL's that can be used to veriy that 3CX has proper access to for operation?
Setup for port forward and Firewall is weel documented for Inbound, but not outbound that is required.
It can also be considerd a "WhiteList" for companies that only providewhite listed access.
From time to time we run into a customer site that were we don't have complete access to the firewall configuration. 3CX should maintain a published list of Internet locations that must be accessible from the 3CX PBX.
It would be nice to actually have the FIrewall test have an optional test to verify those IPs/URLs.
Alternatively - failure to access them could be considered as warnings instead of hard failures.
Most installations tend to be more concerned with blocking inbound connections/ports. If a DNS lookup can be done, it's expected that there will be a connection allowed. I can't recall seeing anything specific for outbound traffic.
