What is the Best Router for 3CX VOIP
Mike-2408
I was wondering, what is Best Router for 3CX VOIP
That's a rather open ended question. Anything that doesn't use SIP ALG. 3CX has instructions for several. We're a Netgate Partner so use pfSense, in order to use IDS, geo-based blocking, etc.
is this will be great with GSM/LTE gateways? also which one is easiest in terms of configurations as I am not into tech that much
I would suggest finding a local 3CX partner or IT firm to help... pfSense is powerful but at times it assumes a knowledge of firewalls, routing, etc.
Almost any router should work as long as the settings are correct and the ports are forwarded.
Another option is to go with a 3CX hosted server, or host with a 3CX partner, so the 3CX server isn't in your office.
Does anyone have experience using Asus AX86U?
WinSip
