WhatsApp Business messages only arrive from the admin's own number — Advanced Access granted, still broken
RolandGraf
SOHO User
Hi all,
We've been stuck on this for over two weeks and have run out of things to check ourselves. Hoping someone here has seen this before.
Setup:
  • 3CX PRO Edition v20
  • WhatsApp Business number: 058 000 00 00 (Meta App "3cx-WA", App-ID *************)
  • Routed via Queue (Trunks & Chat → WhatsApp → Standard route)
Symptom:
Incoming WhatsApp messages only arrive in 3CX when sent from the account owner's own (admin) phone number. Messages from any other number — tested repeatedly with a colleague's phone, a genuine customer number — simply never arrive. No error, no bounce, nothing. The chat just never appears in 3CX.
Root cause we found (but fixing it didn't help):
Under Meta App Dashboard → App Review → Permissions and Features, whatsapp_business_messaging was set to Standard Access (no App Review requested). With Standard Access, a WhatsApp Business app can only exchange messages with people who have a role on the app (Admin/Developer/Tester) — which explained why only the admin's own number worked.
We submitted an App Review request on 21.07.2026 for Advanced Access, including a screen recording of the full flow (WhatsApp message to our number → arrival in 3CX). It was approved on 04.08.2026 (App Review Submissions page shows "Einreichung genehmigt", whatsapp_business_messaging = Approved, no outstanding items).
Problem: identical symptom persists after Advanced Access was granted. A fresh test today (05.08.2026) from a non-admin number still doesn't arrive in 3CX — same as before the grant.
What we've additionally ruled out:
  • License: PRO edition, includes WhatsApp + Queues ✓
  • Meta App Mode: Live and publicly available (since 09.02.2026) ✓
  • Webhook subscription: "messages" field correctly subscribed ✓
  • Server reachability: webhook URL responds HTTP 400 externally (not a timeout) ✓
  • Phone Number ID: identical between Meta and 3CX config ✓
  • Routing: confirmed Queue, not Ring Group ✓
  • No stale/stuck test chats (archived) ✓
  • Not a Meta test number (058 000 00 00 is the real registered number, no test-number flag, no recipient allow-list) ✓
  • Business Verification: completed since 09.02.2026 ✓
  • Meta Activity Log: no configuration changes around the time of the Advanced Access grant — so nothing seems to have been silently reset ✓
Our 3CX reseller (PCETERA) couldn't help beyond suggesting a license upgrade (which we already have — PRO).
Has anyone run into WhatsApp messages from external numbers being silently dropped even with Advanced Access granted? Is there a propagation delay we're missing, or a separate setting (e.g. at the WABA / phone number level, not the app level) that also needs to be flipped?
Any pointers greatly appreciated — this number is on all our active maintenance contracts, so it really needs to work reliably.
Thanks in advance!
**Thanks for the pointer to the health_status feature — followed up on this today:**
1. Checked `health_status` via Graph API Explorer for our phone number. Result: `can_send_message: LIMITED`, but the reason given is "display name has not been approved yet" — an unrelated outbound-messaging limit, not a receiving issue. WABA/Business/App all show `AVAILABLE`.
2. Checked WhatsApp Manager → Phone Numbers → Insights: our number shows **14 received messages** in the last 30 days. So Meta is clearly registering inbound messages — this contradicts a full block on external numbers at Meta's level.
3. Decisive test: used the Webhook Field Sample tool in the App Dashboard (`messages` field, v25.0) with the built-in "Incoming Message" sample (from a foreign test number, not our own). Sent it to our server — result: **"Webhook field messages v25.0 was successfully tested"** at the timestamp. So Meta successfully delivers a simulated incoming-message payload from a foreign number to our 3CX webhook endpoint, and 3CX responds with success (HTTP 200).
**Conclusion:** This points away from Meta entirely. The webhook is received successfully by 3CX even for unknown/foreign numbers — so the issue must be in how 3CX processes the payload *after* receiving it (e.g. some filter/routing logic that only surfaces messages as a visible chat for numbers with an existing contact/role, silently dropping others). Would appreciate any insight into how 3CX's WhatsApp integration decides whether to create/display a chat from an incoming webhook payload.
Hi all — following up again on this thread. It's now been over 3 weeks since we first reported this (webhook delivery confirmed successful via Meta's own test tool, HTTP 200 from 3CX, yet messages from any number other than the account owner's own still don't appear in 3CX). If anyone else has run into the exact same "only my own WhatsApp number gets through" symptom, we'd really appreciate hearing how you resolved it. Happy to share our full diagnostic writeup if useful.
It’s interesting that Meta shows all messages as successfully received, while they do not appear in 3CX. Please perform the following tests and check whether the logs provide any key information.
First, set the 3CX logging level to Verbose, and then run these two separate tests:
TEST A
  • Sender: Administrator’s number
  • Expected result: The chat appears in 3CX
TEST B
  • Sender: External customer
  • Current expected result: The chat does not appear in 3CX
Please let me know what you are able to capture in the logs for each scenario, particularly for Test B and any entries related to WhatsApp.
Thanks for the pointers — we don't have a separate "Verbose" log level in the Admin Console UI (only Info/Warning/Error, fixed), so we used the Event Log filtered on "WhatsApp" instead and ran a controlled live test just now: [...] a simulated test payload from Meta's dashboard reaches 3CX far enough to produce a routing-warning log entry, but a real message from a genuine external WhatsApp number produces absolutely no trace in 3CX at all — success or failure. [...] Any idea what could cause that gap between simulated-payload delivery and real-traffic delivery?
There you will find the verbose logs: 1786956365497.png
**Kurzfassung (Englisch, Bullet Points):**
> Follow-up on the Activity Logs tip:
> - Enabled Verbose logging as suggested
> - Ran a control test from the owner's own number (the one that works, arrives fine)
> - Filtered Activity Logs for "whatsapp" → **zero results, even for that successful message**
> - So this log module doesn't seem to capture WhatsApp traffic at all, success or failure
> - Back to square one — still trying to confirm whether Meta even attempts delivery to us for the real external number
Dont filter for "whatsapp" just send the message and have a look into the log, you will find something.
Thanks bitn2 — we actually already did exactly this on 17.08: ran a live test with a foreign number (not the owner's) while watching the unfiltered Activity Log stream (Verbose level enabled) around the test timestamp. Result: nothing shows up at all — not even unrelated background noise was affected, the incoming message simply never appears anywhere in the log, filtered or not. So it looks like the message never reaches 3CX's logging layer in the first place. Next step on our side: checking Meta's webhook delivery/error counters to see if a delivery attempt even happens for our number.
Update — conclusive proof the issue is on the 3CX side, plus a new clue
  • Ran a controlled test with a neutral webhook receiver (not 3CX) as callback, sending two messages in the same batch: one from an unknown/foreign number, one from my own number (control group). See screenshot below — both captured with valid signatures (x-hub-signature-256), identical payload structure, from Meta's own servers, only the sender number differs.
  • Switched callback back to 3CX — only my own number created a chat. The foreign number's message (proven delivered, same structure) produces nothing.
  • → Rules out every Meta-side cause chased over 6 weeks: App Review, Advanced Access, Business Verification, Health Status, WABA↔App subscription, webhook field version (tested v25 and v26, identical behavior).
  • New clue from the 3CX event log: when the destination number is unrecognized, 3CX logs an explicit warning ("Cannot find valid routing for incoming Whatsapp message to number: ..."). When the destination is correct and only the sender is unrecognized (our actual bug), there's zero log entry anywhere — no warning, no error, nothing. Suggests unknown senders get silently dropped instead of logged/routed.
{"object":"whatsapp_business_account","entry":[{"id":"<WABA-ID>","changes":[{"value":
{"messaging_product":"whatsapp",
"metadata":{"display_phone_number":"<our hotline>","phone_number_id":"<PHONE-ID>"},
"contacts":[{"profile":{"name":"<redacted>"},"wa_id":"<external number>"}],
"messages":[{"from":"<external number>","timestamp":"1788188005",
"text":{"body":"Test extern"},"type":"text"}]},
"field":"messages"}]}]}
This is a rather unusual case, my friend.
Just to confirm once again: you posted this case in the forum section for 4SC licenses, which do not support WhatsApp integration. To rule this out, are you certain that your license is the PRO edition?
Also, which 3CX V20 update are you currently using? Is it Update 9?
I suggest deleting the WhatsApp trunk and creating it again from scratch. That may resolve the issue.
**Update — trunk rebuild did not help, points to a deeper bug**
- Running the **latest build** (Version 20.0, Update 9, Build 995) — so this isn't a version-lag issue either.
- Followed the suggestion: **deleted the WhatsApp trunk entirely**, did a **full OS restart**, then **recreated the trunk from scratch** with identical configuration (same phone number, same phone number ID, same access token, same routing to the WhatsApp queue).
- Also enabled **Chat Log** beforehand (was previously disabled) to see if it would capture anything for foreign-sender messages.
- Confirmed on Meta's side: `messages` webhook field is still subscribed (v25.0), callback URL updated to the new trunk's webhook and verified successfully.
- **Result: identical behavior as before.** Only the admin's own WhatsApp number creates a chat. Messages from any other number still produce **zero trace anywhere** — no chat, no event log entry, no chat log entry, nothing.
- This was tested with a live foreign number, not the dummy test payload.
Since a full trunk delete + rebuild + OS restart + already on latest build didn't change anything, this looks less like a stale/corrupt config and more like a genuine processing bug in how 3CX handles inbound WhatsApp messages from unrecognized senders. Happy to provide more diagnostic detail if a dev wants to look into it.
Addendum — isolated it further with a direct curl test (no Meta involved at all)
Sent a raw POST directly to the webhook URL myself, bypassing Meta entirely — payload with the correct destination phone number/ID but a foreign sender number.
  • Result: HTTP 204 (accepted without error), but no chat created, zero event log entries.
  • For comparison, when the destination number in the payload is wrong (like the "Test" button's dummy payload), 3CX does log a clear warning ("Cannot find valid routing..."). So that lookup path is logged correctly — but resolving/creating a chat for an unrecognized sender fails completely silently, no logging at all.
Reproducible with a single curl call to the webhook endpoint, no Meta infrastructure needed. Happy to share the exact payload if a dev wants to reproduce it locally.
Hello, if you put the logging to verbose, still nothing in logs? What shows up in a packet capture?
And what is the default destination for messages from new numbers?
Hi Kyriacos,
Thanks for following up. A few updates:
  1. Verbose logging: I could not find a "Verbose" log level option anywhere in the Admin Console — the Event Log severity filter only offers Info/Warning/Error (no 4th option), and this is with confirmed full admin access. I also checked the Support Info export route on the Dashboard.
  2. Instead, I exported the complete Event Log (845'478 lines, covering several weeks of history) and searched it for "WhatsApp": only 4 matches in total, all identical — Meta's dummy test number +16505551111 (from the API dashboard's "Test" button), never a real sender. For actual incoming messages from real, external numbers (which we know arrive at Meta's side and were even physically received/stored once, see the recovered voice message from an earlier message) there is not a single log entry anywhere in the complete, unfiltered export.
  3. I also ran a packet capture (Windows netsh trace) during a live test with a real external number sending a message. Since traffic to our server is HTTPS/encrypted, this only confirms packets arrive — it can't show the decrypted payload, so it doesn't add anything beyond what we already demonstrated with the webhook.site interception (which proved Meta delivers the correct payload).
  4. Default destination for messages from new numbers: it's a Queue (not a Ring Group) — Queue 805 "WhatsApp". This was explicitly reconfigured and verified during the trunk delete/rebuild on Sep 5.
So to summarize where this leaves us: Meta demonstrably delivers correctly (webhook.site proof), 3CX accepts the payload (curl reproduction, HTTP 200/204 response), but never creates a chat for unknown senders and never routes it — even to the configured default queue — and this happens with zero trace anywhere in the complete log history, verbose or not.
Is there a next diagnostic step on your end that doesn't require Wireshark/TLS decryption on our side, or should this go to engineering directly as a bug report?
Best, Roland
Hi Kyriacos,
Big update — I think we finally found where the message actually goes.
I sent 3 fresh test messages (TEST50, TEST51, TEST52) from a real external/foreign number to our hotline while Verbose (finally found it) logging was active. Searching the Activity Log and Event Log for "whatsapp": zero results, as before.
BUT — I checked two places I hadn't looked at before:
- Reports → Messages: shows all 3 test messages with full content, sender = the real external number, destination = "Helpline, Help (100)".
- Reports → Chat Log: shows an older real external message too (same number, different day), destination = "WhatsApp (805)" queue.
So the messages ARE being received and logged with full content — just not in the Event/Activity Log.
However, in the actual "Chat" menu (the live chat interface), only my own number's chat conversation appears and is actively delivered as a live chat popup I can reply to. The external number's messages never show up there as a chat conversation, even though they're clearly logged elsewhere with full content.
One nuance I noticed: in the Chat Log report, my own test and the external number's message show DIFFERENT destinations — mine went to our internal ring group (extension 500), the external one to "WhatsApp (805)" queue. So this might not purely be about "known vs. unknown sender" — it could be routing/queue-related instead, if queue 805 "WhatsApp" behaves differently from a ring group in terms of surfacing a live chat. Both numbers are messaging the same hotline number from the outside, so I'd expect the same routing unless something distinguishes them earlier in the pipeline.
So the corrected picture is: it's not that the message never arrives or is silently dropped — it arrives and is logged, in detail. The failure is specifically that no live/visible chat conversation is created in the Chat interface for messages routed via (or associated with) queue 805 "WhatsApp" — while messages ending up at the ring group do get a live chat. Could this be a known issue with chat creation for a specific destination type (Queue vs. Ring Group), or with contact matching for numbers that aren't already stored as a contact/extension?
Best, Roland
So, the next step is to check for the whatsapp messaging trunk, what routing is set - what the default destination is and where the DID is actually assigned:
Then in queues we have, would be good to confirm settings:
Now ring groups do not really have detailed message handling configuration, as they are "meant" to handle live calls.
From your log it seems that the (new number) messages are ending up assigned to ext.100. For your own number tests, since you have an active conversation the messages pop up on your extension - the system will maintain a conversation association so the same service agent can continue talking to the same customer.
I believe there is a simple crossed wire in the routing for the whatsapp number, once identified it should be an easy fix.
Teemal
