Where do extensions change their caller ID?
Alphabetic
3CX MVP
https://www.3cx.com/docs/manual/sip-trunks/
Selecting caller ID​
If a user has multiple DIDs, it will be possible to select a caller ID for an outbound call in which case it will automatically use the trunk assigned to that DID and set the caller ID accordingly.
How does one do this?
It's not what you think it is...
You hit this dropdown and choose which CID to use
But that requires admin level which the KB doesnt suggest. It suggests a user can quickly change?
So what role is your user there?
The guide above is actually for the Administrator of the system (3CX Administration Manual).
User with the role User, cant see those options as you need to access the extension settings via the Admin console of the System, which regular user don't have.
Is it possible to withhold number from the extension DID?
amazingbv
