Where is the AutoAnswer Setting in PWA?
abrown
Hello
As we are now told the Windows Version should not be used as the preferred option is the PWA.
Where is the setting for "Autoanswer - Enable/Disable?"
I have a client who does not have the Thick client installed, somehow auto answer is enabled but I cant for the life of me find out how to turn if off as the option doesn't appear in the PWA?
Any thoughts?
Should be in Settings > Audio/Video.
Nope. There is no "Auto Answer" setting in the PWA "Settings Audio/Video" menu.
Wtf, just checked and it's not there. But calls are still automatically answered? Makes no sense if the setting isn't there.
Hence why I raised the question in the forum.
Try clearing the cookies, cache and local storage for the app/site. (Like, uninstall the PWA and clear everything for that site.)
Settings are stored in local storage so we'll see if it stops doing that.
Thanks Will give that a go, I did look for the settings in the edge app data but couldn't find anything human readable to be able to change. Unlike the desktop .xml file which can be edited directly.
DaanLosning
