I know .... but my question is about the API it self.@VoIPTools has all that and more in their Relay API.
The Call Control API itself is undocumented and unsupported. The REST API isn't ready yet.I know .... but my question is about the API it self.
Ps. this answer is from my testing account
I would strongly recommend using VoIPTools relay to prevent any problems as they are experienced with that API.
Agreed. Tracking that takes a lot of work.There is no event specifically for presence status changes. You have to subscribe to Extension/DN events. First you have to know the previous status, then with every event check whether the status has changed. It is a pain in the backside.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
