Whom can assit unblocking WAN IP blocked?
Cyctronic
SMB User
No one... if its your wan ip blocked on smb, you need to solve the problem and wait 24 to get unblocked.
I'm still WAN blocked can't access my admin console what to do now!
You need to solve the problem first. Did you configured any hardware phone to connect your pbx?
You presumably have something trying to log in and failing…disconnect phones, apps, etc.
If you are using a VPN try a direct connection.
Reactions: bitn2
Have disconnected 2 days ago
There must be more... You can try from a different wan ip (mobile phone or somewhere else).
At this stage i'm trying to setup a Yealink desktop phone over SBC which was my initial fault which i fixed. Now the desk phone is disconnected but still WAN blocked, i can't disable the SBC as i'm locked out from the console?
Just try to login from your mobile phone over LTE. If this is working you need to find the stuff who is trying to login with wrong configuration.
will try and revert if it doesn;t work
Isuru Eranga
