Why the Firewall Checker Does Not Lie
KaterinaK_3CX
Hello sir,
Because what I wireshark is almost the same with the guide.
For test 2 in the guide, what should be the correct response?
Thanks.
Peter
Hello sir,
Thanks.
Hi Peter,
In Test 2, the PBX sends the STUN request to IP A of the STUN Server, but then the STUN server replies from IP B which the PBX doesn't know.
The example in the screenshot shows that the PBX sends 3 requests without getting a response. This means that basically the screenshot of Test 2 shows a failed attempt.
Hi Peter,
Hello Nick,
So Test 1 ans 2 result is just like what we've done now. We're using Palo Alto FW and also have Load Balancer (FortiADC) to do the 1-to-1 NAT.
Right now call between mobile phone app and laptop app (inside/outside Office) are normal, but we don't have a SIP trunk to VoIP service provider. We are planning to test the SIP trunk soon , but the FW checker result always bothers me. If There's something wrong with my configuration, would you give me the direction so that I can try to fix it? Thanks.
Peter
Hello Nick,
With Providers/SIP Trunks, this may indeed be a problem especially if they use different Media Servers, which is very common, because there will be cases where your PBX will receive UDP packets from "unknown" source IPs (what Test 2 tests).
Unfortunately there is not a lot more I can advise you, other that it's a good idea to first get this fixed before putting a SIP Trunk in.
Most firewalls have different ways o doing things and configuring, but if you are looking for examples of how to correctly configure other firewalls, in case it gives you some hint, there are a few guides you can see here:
https://www.3cx.com/docs/manual/firewall-router-configuration/#h.jtpzj3r4slqq
Reactions: PeterCheng
Hello Nick,
Thanks for your feedback.
I believe that it's our PA FW issue, becasue I can see lots of packets were dropped by our FW (it should be the test packets coming from 3CX stun server). I did the wireshark and found 3cx pbx sent request to 54.39.182.217, but no response. and inside some other response changed-address attribute showed the ip is 51.79.116.90. I then checked our PA firewall for this ip and found lofs of packets coming from 51.69.116.90 have been dropped by firewall. And if I filter the FW traffic log when clicked 3cx firewall checker, I can see indeed the dropped packets from 51.79.116.90, it should be the reason why I cannot pass the 3cx firewall checker!
We will think about such behavior and how to avoid the check mechanism in the PA FW, thanks.
Peter
Reactions: NickD_3CX
Hello Nick,
Peter
That's it!
Exactly, if you find dropped packets from the IP that was referenced in the other STUN Requests, that is what is causing Test 2 to fail.
Once you fix that, from your description, it should make the Firewall Checker pass as well.
@PeterCheng
Excellent! Glad to see you got this resolved!
BIT Incorporated
