Windows Softphone V5.1 Beta
ThomB_3CX
Staff member
New Receptionist panel for easy drag and drop of calls.​
The latest 3CX Windows Softphone BETA focuses on making the panel for Receptionists and Queue Supervisors more efficient for use. The Receptionist panel allows receptionists to process calls more efficiently, using drag and drop transfer. Also, receptionists can change the...
Amazing update. The new drag en drop feature is a great addition.
The overal cleanup of configuration settings in the softphone, makes it a lot easier for a user to direct find what you need.
Being able to switch between a compact view and 'normal' view is also great.
Would love to see this option make its way to the BLF panel. As the curent view is sometimes to compact.
Great work and props to the 3CX team!
Great Update, but still the issue of Ringer On/Off still PC keep rining with both
@ArneDery thank you for the nice feedback! We have two options for the blf panel? Or do you mean you want a less compact version? We definitely want to make more views improvements to the softphone ... Be supposed to screenshot what you would want. @Shadi Bamalhs (ECOLOR) thank you for the feedback. We will check about the ringer
Reactions: GregG_3CX
Something kinda like this, which is inspired on the new panel sidebar ;)
jb_erp
