Windows v16 Upgrade Process?
loyer
My linux installs upgraded to v16. When I view my windows installs and click on updates, it says my system is up to date still at v15.5....
Is the windows v16 coming later?
Or is there a different process for upgrading windows to v16?
Thanks. I saw that post but I assumed it was only for the beta release. Is this going to be the case for final release?
Yes, I do think so, because all 3CX PBX’s I have installed on Windows do not show the new v16 release. On Debian they show up.
It's explained in that thread but they add a new service for CFD in Windows that I guess they can't upgrade to. And before v15 you always had to backup/uninstall/reinstall/restore to upgrade versions anyways so that will of course still work.
Reactions: JohnS_3CX
This is correct. As a new service was added to the PBX the Windows installations cannot be updated. To update to V16 you need to backup / uninstall and then re-install using the backup.
kevlaboom
