Solved Withholding number ext to ext
Alphabetic
3CX MVP
Internally no, but if I was the manager I would call from an external number they don't know ;)
Why not dial out through the trunk and then back in though using *5 ?
They could do that but that call will cost
Reactions: NickD_3CX
You could try creating a loopback trunk...
1. create SIP trunk with 127.0.0.1:5060
2. create outbound rule(s) for this trunk.
Direct the call back in to the desired extension. I'm, not certain if caller ID will be changed to what is put in the outbound rule for that trunk, or can be blocked. You would have to do some test calls. It would use two simultanious calls, but not go though your provider.
Thanks all.
found this in the phone.
template doesnt overwrite it:
Features > Phone Settings
Reactions: JohnS_3CX
Kayla Norris
