X210 v1 v2
rich_s
Hi - there are some additional features available on the Fanvil X210 v2 that I'd like to get hold of. After a couple of calls it sounds like the v2 hasn't made it to the UK market yet.
Can anyone confirm that or suggest if that is true, or if there is another route to purchase the X210 v2?
Thanks in advance.
Hi Rich,
They are labelled like a regular X210 with some fine print showing Rev B V2. They might already have them and not know about it..
Example of an X6U-V2
Thanks John - is there a link to approved resellers?
Reactions: JohnS_3CX
No but you might want to ask your 3CX Partner, or find a partner from our list:
https://www.3cx.com/ordering/find-reseller/
They tend to know the local suppliers and could be able to sort you out if you can't find any devices yourself.
Diogo Maia
