X210-V2 NEED TO PROGRAM BLF KEYS WITH SECONDARY trunk
sonnyh1
SOHO User
I have x210-v2 that has several trunks.
I want to program the BLF keys as memory key, BLF/CONF, XXXX@SIP4.
I find no wat to do this other than in the phone GUI interface.
When 3CX updates it wipes out the BLF/CONF & XXXX@SIP4 settings.
Is there a way to accomplish this?
Thank you
That is not what BLF keys are designed for. If you make changes directly on the phone, they will always be overwritten by the provisioning process. If I understand you correctly, you want to use a BLF key to make an outgoing call via a different trunk? You can do that using the softphone, starting with the latest update.
