Xorcom XR0011 Astribank
KhaledQuenawy
Any one use Xorcom XR0011 Astribank Gateway with 3CX , how should i add it as generic sip trunk or generic gateway
Hi @KhaledQuenawy
Since this is not a supported device, you will have to do it all manually. Firstly I would start with the documentation of the gateway to see what requirements it has for anyone to register on it and make calls.
Then I would setup a generic gateway (considered to be local to the PBX) or as a trunk if it's not local in networking terms or you need the additional settings that trunks provide.
You will have to run some captures and analyze in Wireshark to see what happens and then adjust your PBX accordingly, but we cannot guarantee it will work as intended
Schnittker
