Yealink Firmware Update Failing
Scott EIT
Have two different models of Yealink IP phones that are both failing to update. T41s and T19P E2. I'm thinking the issue is due to the existing firmware being too old to update to the latest supported versions. Is there anywhere I can find older versions of the software so I can try installing in steps.
Existing firmware versions:
66.83.0.55
53.83.0.55
I was having the same issue the other day with some Yealink T41Ss. I have not tried it yet, but someone said I would need to contact Yealink to get the in between firmware versions to fully upgrade.
get the 66.84 version of firmware. then it will auto update via management console. I haven't dealt with the 53.xx but i assume it is similar.
Reactions: CPMM and Scott EIT
Unfortunately this did not work for me. I got the 66.84.0.90 firmware from the Yealink Website, and the update still failed. :(
Looks like I'll have to get in touch with Yealink if I want the few T41Ss I have fixed.
Try the earlier version DrLloyd provided. Worked for me.
Reactions: CPMM
SupportRock
