Yealink Management Cloud Service
Shahril
Hi All,
Any of you guys already use this tool? Any idea why mine most of the phones showing offline even though it's on service and Im 100% sure that the MAC and S/N is matching.
Is there anything we need to do from 3CX side?
I think you should probably ask this question on the Yealink forum, because 3CX does not require that service to run, and depending how you use that service it may conflict potentially with your 3CX installation. Any particular reason you are using this service?
[email protected].
