Yealink Multi-Line/BLF Notification
CaspMR
Intermediate Cert.
Outside of a custom template does anyone know of a way to add a second line to a Yealink that provides a unique notification from direct calls? I know BLFs will flash red when they ring but the default template for 3CX doesn't trigger the phone to alert audibly. My main goal is a corporate compliance line that rings two phones at once, providing a unique identification, before going to a voicemail and power dialer I've built.
Ideally I would love an option in the 3CX phone provision menus of Yealinks to enable or disable BLF ringing but with the changes to the suggestion forum I can't really post that...
Hi @CaspMR
The default behavior is indeed the one you see currently, with the LED state flashing, and there is no supported method outside of custom templates that I am aware of to change this.
There are no plans currently to alter this behavior natively from the 3CX side of things.
Finatra.us
