Yealink phones not passing through tagged VLAN quickly enough when rebooted
maindriver
This is an example how our network works.
VLAN50 = vlan for phones
VLAN80 = vlan for computers connected to phones
Switch port is set to
50 untagged, 80 tagged.
In 3cx for the Phone Provisioning,VLAN Configuration, Enable VLAN for PC PORT 80
If I connect a phone up, it gets the correct settings, works on VLAN50 etc. Connecting a PC to the PC port after the phone has booted, will result in the PC being on VLAN80. However if we then reboot the phone, the PC port will at first be given VLAN50, we are then required to disconnect and reconnect the network cable to rest the network connection of the PC to get the correct VLAN.
Is there a way of telling the Yealink phones to hold off sending traffic to the PC port until the phone has fully booted? It seems to act as a dumb switch until it has booted and provisioned fully.
This is in a 150+ phone/pc set up, so making any other changes to the switches / configuration would be a real pain.
Thanks in advance.
3cx version
Professional Perpetual 15.5.15502.6License
Phones
Yealink T42S fw 66.83.0.55
Yealink T19P_E2 fw 53.83.0.55
Hi maindriver
The way the phone behaves I think is to be expected, it will not know what settings to use until the OS boots up and reads whatever we provision it with, but we can't control what it does until then.
I think this is more of a matter you should ask on the Yealink forums or maybe you need to consider a work around.
Reactions: maindriver
Thanks, I assumed it would be a Yealink firmware thing, must be possible for them to set a delay. Figured I'd check here too.
edit, also, thanks for the super fast reply :)
[email protected].
