Yealink SIP-T46G Not Supported?
myrich22
Forum User
I'm getting the message:
You are using Unsupported phones or phones with custom templates which may cause issues.
For a list of supported IP Phones visit this page.
However, the "this" page link ( https://www.3cx.com/sip-phones/ ) says the T46G is supported. As far as I know, I'm on the highest (and last) firmware update for the model (28.83.0.120).
So, not sure which is wrong (error message, web page, my setup).
Ideas?
Rich
When you added the phone to the ext, the pull down menu nammed: Choose from available models :
Did you add a template from ---supported--- or ---custom---
Hello, I added from supported "Yealink T46" (it doesn't say T46G). As far as I can tell, that is the correct model.
Reactions: nub
I think that is it! Thank you!
As above, phone is running the incorrect firmware.
select the phone in the list, and click on firmware icon along the top
Reactions: AWS2P
Wecare_ITA
