Yealink T40G - No Service - Invalid Account
thereverendd
I have just set up my T40G and was able to have it provision AUTO by putting in the provisioning link. The phones FIRMWARE is up to date
but the phone displays. I have OTHER phones on the same network and they are working 100%. This one the only one with an issue. Can someone help
me get this up and running? Please and Thank you
So it looks like it provisioned, but didn't register. I'm guessing it's setup as STUN and you didn't uncheck the box 'Disallow use of extension outside the LAN' for that extension. Looking in the logs you should see indicators of this.
That was one of the 1st things I did. Also in the phones list it is not showing the phone either.
Not sure if this helps but this is what the log says
It will only show the phone in the phone list if it's registered. Since it's not registered, it won't show in the list. I'd try to factory reset the phone again.
Check 3cx blacklist records and delete any records
Make sure you have entered the phone MAC address correctly
Factory default the phone, and enter the ext number and voice mail pin to configure the phone https://www.3cx.com/sip-phones/yealink-t4-series/. - Remote phones: Provision via RPS server
Reactions: JohnS_3CX
I'd be surprised if it's on the blacklist as the OP says there are other phones on the same network (and presumably with the same internet connection) so if the IP was blacklisted then they would all not work.
hughesdouglas
