Solved Yealink T43U
JSimao
Good afternoon dears,
Iam tryng to set up one ip phone yealink t43u on 3CX, but the phone does not autenticate.
How can i do it outside LAN?
I followed the instruction in this link, but it is for LAN: https://www.3cx.com/sip-phones/yealink-t4-series/.
I tried to configure the ip link with link of provisioning that i have on 3cx extension and does not worked. I tried also to set up manually the ip phone and it does not autenticate as you can see in attached imgs.
Best regards
Good evening dears,
After Deactivate certificate o phone and reprosivosion again, it started to reprovision and then rebooted phone.
Now there is not audio on calls and theres a red light blinking.
Best regards
If you will use the phone outside the LAN, you will need to install a 3CX SBC at the phone site.
STUN mode requires you to port forward any ports the phone is using, treat it like a server.
Hello JohnS,
I have another clients that use Ip telephone outside LAN and dont have 3CX SBC.
Thanks in advance
That doesn't inform you why this specific client isn't working though.
You can look at other cases in the forum for STUN, the subject has been discussed many times over in the Fanvil / Yealink / Snom / Other categories under IP phones.
Hello Jonh,
I made manually configuration and now the phone works well and there is audio.
Reactions: JohnS_3CX
Finatra.us
