- Joined
- Nov 12, 2018
- Messages
- 379
- Reaction score
- 24
Here is the situations.
1. I plugged in brand new t46s phone and I can see it under phones. I then created extension 200,201,202,203,204,205. I have assigned each phone to each extension. Which is working out fine. I was able to make calls and recieve calls.
2. Issues is I created the extension wrong. So what I did was removed 200,201,202,203,204,205 extensions and now under the tab phones I do not see any phone showing up.
3. I then created extension 300,301,302,303,304,305. Still phones are not showing up under phones.
4. I manually have to reset yealink t46s phone to factory default by pressing the OK for 5 sec and a prompt ask me to reset to default. which I did. All phones are reset back to default. I can login to the web interface of each phone. But it still do not show up in the 3cx.
Is there something special I need to do on the 3cx side?
thank you
thank you
