Yealink T4x Template - network.vlan.vlan_change.enable??
Jase1313
New User
Template: yealinkT4x.ph.xml
Line 1317
The description of this option does is difficult to understand.
"It configures LLDP or manually VLAN can't obtain IP,..."
- The sentence starts off by saying It configures LLDP or manually VLAN... which does not make sense to me.
Can someone explain what this option will do for me?
##It configures LLDP or manually VLAN can't obtain IP, whether to switch to other methods of VLAN or closed VLAN to get IP
## 0-Disable 1-Enable
network.vlan.vlan_change.enable =
Hi @Jase1313
Our template leaves that field empty, meaning that we do not provision it at all.
Go to the manufacturer's site and look for the Yealink Administrator Guide.
Yealink provides a file that goes into more detail about what each parameter does and they should be able to answer your questions.
Finatra.us
