Yealink T53 Register Failed.
DmitryS
Hi, I can't provision a phone (Yealink T53). Reset to factory, update firmware, provision as a router phone on a cloud based 3CX, restart. But the phone says No Service and the square is red next to the Yealink phone on the 3CX Admin Console. The phone has a warning: Account Unregistered! Thank you for your help in advance.
What is the firmware version of the phone?
It's the one that 3CX has on its firmware update page - 96.86.0.76
I have tried this half a dozen times from different locations (to make sure it wasn't a modem/firewall issue). I also have a Yealink T42S phone which I tried before purchasing T53. Same result. I am aware it's not a router phone but wanted to try anyway.
After the factory reset, the phone does get the provisioning but fails to register?
Which provisioning method do you use?
@DmitryS Did you resolved this issue?
The issue is not resolved. I have done RPS provisioning.
I have not run into it myself with several Yealink models but there have been 2-3 threads stating that downgrading to the .74 firmware is required.
