- Joined
- Feb 4, 2025
- Messages
- 4
- Reaction score
- 1
Good day,
I hope this post is in the right place, and I apologize if the text is too long.
Each branch has an SBC, and the phones are located in VLAN 160 (our phone VLAN).
Here at the headquarters, around 150 phones are also in this VLAN.
The 3CX system itself is located in a DMZ.
Error message: "No Service"
This issue has been occurring more frequently over time.
Previously, with older firmware versions, this problem did not exist.
Affected devices vary; there is no clear pattern or specific set of phones.
Since we use a RADIUS server (Aruba ClearPass), we can trace where the issue occurs.
We see that some phones sporadically re-authenticate. It appears as if the phone is "network-resetting" itself.
Following this, the phones undergo RADIUS authentication again and receive a new IP address from the DHCP server.
During this process, they are unreachable.
The issue becomes especially problematic when it happens during an active call!
[09 21:29:02][killall:2784] send signo(9) to [cable_dot1x:2780].
[09 21:29:12][kill:2932] send signo(15) to [svc_hpd.sh:373].
[09 21:29:12][kill:2932] send signo(15) to [appstart:507].
[09 21:29:12][kill:2932] send signo(15) to [appstart:2125].
[09 21:29:12][kill:2932] send signo(15) to [sh:2927].
[09 21:29:12][kill:2938] send signo(15) to [sh:2933].
[09 01:00:26][killall:1628] send signo(9) to [dot1x.exe:1049].
[09 01:00:35][killall:1641] send signo(9) to [dnsmasq:865].
[22 01:00:21][killall:1359] send signo(9) to [dnsmasq:875].
[22 01:00:21][killall:1392] send signo(9) to [dnsmasq:871].
[23 08:10:14][killall:3381] send signo(9) to [dnsmasq:1602].
[03 01:00:21][killall:1374] send signo(9) to [dnsmasq:867].
[03 21:09:26][killall:2011] send signo(9) to [dnsmasq:1595].
[03 21:32:00][killall:2263] send signo(9) to [dnsmasq:2012].
[03 21:43:14][killall:2514] send signo(9) to [dnsmasq:2264].
[03 21:46:03][killall:2745] send signo(9) to [dnsmasq:2515].
System Specifications:
Thank you and best regards!
Please excuse me, I had this text translated using ChatGPT.
Structure Overview:
We operate approximately 1,200 Yealink T57W phones across 25 branch offices.Each branch has an SBC, and the phones are located in VLAN 160 (our phone VLAN).
Issue Description:
In general, the phones work without issues:- Registration, telephony, and provisioning function flawlessly.
Observations:
- On the switch, we see that the MAC address re-registers on the interface—nothing else unusual.
- The issue occurs irregularly: sometimes 1-2 times, other times up to 10-20 times per device.
- Even rarely used phones (e.g., in the kitchen or server room) are affected.
- It also happens on phones without an SBC, connecting directly to 3CX.
- Some weeks, the issue is more frequent, while in others, it barely occurs.
Error Logs (Folder "Crash"):
[09 21:29:02][killall:2777] send signo(9) to [cable_dot1x:1908].[09 21:29:02][killall:2784] send signo(9) to [cable_dot1x:2780].
Phone System:
- Microsoft Windows Server 2022
- CPU: 16 cores
- RAM: 64 GB
- Storage: 190 GB
- 3CX Version: 20.0 Update 4 (Build 487 Release)
Phones:
- Quantity: ~1,200 Yealink T57W
- Firmware: 96.86.0.81
- Hardware Version: 97.0.1.0.0.0.0
