Yealink T58 / 2N IP Verso Intercom - Custom Template?
mattlowe67
I'm wondering if anyone with this setup can tell me how they provision their T58 phones with a 2N IP Intercom system. Do you use custom templates? I'm looking at the T58 template and it seems there are lots of missing settings for the door phone features.
Here is a PDF with those settings http://support.yealink.com/attachme...one+Feature+on+Yealink+Smart+Media+Phones.pdf
Can I add these configurations lines to the template myself? And if I hard code these values, values that are not hard coded can still be over ridden in the 3CX GUI like BLF keys, etc?
You should be able to manually configure the phone with the door phone settings and as long as they don't conflict with values in the template they will stick.
Ah, amazing. Thanks! I was worried the 3CX config would overwrite manual config on the phone.
That being said, can I add these custom parameters to a 3CX custom template? Or will 3CX dish out only what's already in the template. Would be nice to provision door settings automatically from 3CX once I start adding more T58's
You absolutely can make a custom template but that isn't supported by 3CX.
florentrobineau
