- Joined
- Mar 24, 2008
- Messages
- 38
- Reaction score
- 1
Hi Community,
since a few weeks users report low and bad voice quality if Yealink SIP T58A is used with Plantronics CS540 which is a wireless headset. The problem only exist if the headset is used. The handset of the IP phone delivers crispy and normal sound.
It's difficult to say if this problem is existing from beginning on (6 months) but I don't think so. It seems to be a problem of the interaction between SIP T58A and CS540 Headset. It's possible that this problem occured after updating firmware and / or 3CX update which will be done automatically.
In the past (or maybe until now) 3CX provided some values in their autoprovision CFG files which are regarding Yealink not optimal (voice.handfree_send = / voice.handset_send = / voice.headset_send = ).
Do you know about this issue and a possible solution?
Thanks for any help!
Best regards
Best regards
