Solved Yealink Telephones dont show the Status of other Local Phones
xerxes35
Hallo, i hve a realy mysterius Problem, the Telefphones in the Locla LAN dont shows the Status of other Phone in the same Local Network, i set all Ports, all are correkt, any call did Work, call to other phones too.
i try anything i know to fix that, but its not Working ?!
My 3CX Android App is the same, all Calls working, but its showing offline ?!
Has anybody any idea for that Problem?
By offline I assume you mean unregistered? Or do you mean registered in extensions but not showing anything in the phones tab?
Hello @xerxes35
Do you mean that you do not see if an extension is Available or Away or DND? If so then please note that this is not possible currently as currently you need to use a 3CX client to see the status of extensions.
Okay, i solved the Problem, i installed new and all work fine now. Thanks
Glad to see the issue has been resolved
apbGroup
