Yealink Template Updated to 91548, What changed?
mhemmes
The Yealink T23,T27,T4X,T4XS template 89556 was updated to 91548. What's been added / changed?
3cx does not list the changes,
You will have to use Notepad++ and compare the two templates files
Notepad++ also has a tool to compare text files.
Hi Allen,
thanks for info , i've never used N++ to compare files, as i don't know where to find this feature in the software. Winmerge is natively done for that and so easy, even when you never used before,you are quickly in to do what you want.
Hi Allen,
That's fine. For the benefit of others, and to complete the thought - Notepad++ has an extensive library of optional Plug-ins that can be activated if needed.
Wecare_ITA
