Yealink W52P - Cannot Connect
ApexMiller
Was hoping someone could shed some light on this. I'm stuck, and I really could use someone to show me the light and add to my troubleshooting tree.
First time forum poster, long time reader.
Moved company to a new server and rebuilt it from scratch. Everything worked well for the most part except for the W52P.
Previous Firmware was 25.81.0.60, I then downgraded to Firmware Version 25.81.0.30. Massive factory resets, and starting over trying to catch some kind of mistake on inputs.
There was a custom xml for the 52 that was in version 16 that I tried as well. I've whitelisted the IP and nothing shows in the event logs.
Appreciate any insight. Much appreciated.
Hello @ApexMiller
Why don't you use the easy/supported way to configure and provision your w52p ?!
Hello @ApexMiller
Hi there. I tried this as well. I believe it's not the supported way, but you are correct there is an option for it and I have tried it with no luck.
You have a local IP begining by 34.16 ?!
Appreciate the support, to those who contributed. Thank you for your time.
Installed SBC on a server and boom, we are up and running. I have never had the need for a SBC until now. Will keep this trick in my tool belt.
Thanks again for your time and troubleshooting.
No members online now.
DejanMDS
