Yealink w52P not authenticating
ompartsinc
SOHO User
Hello Everyone,
We have 3 yealink w52 bases with phones at 3 different locations, 2 of those are working fine (so i know the setting and.all are working) but the third one is not working at all. It always blacklists the ip on the Management console and says Register Failed on the yealink admin portal. The reason for blacklisting is PBX:blocked for too many failed authentication; User agent: Yealink w52p. I know the pass and all are correct.
The third location is running an apple airport router and it is connected to that directly, is there a problem with it working behind an apple airport extreme router. I cant seem to figure out what else could be causing the issue.
Thank you
No members online now.
DejanMDS
