Yealink W60B base station issues
JackT24
Hi there,
I have had some issues with our W60B base station with 4 portables connected.
First issue which happened a couple of times is the phones would show offline in 3CX, the only other phone on site is a Fanvil X4U that was still up and a PA that was still up.
A restart solved the issue.
I have also updated the base station to the latest firmware along with the handsets, along with resetting them and regenerating credentials.
Another issue was the phones would ring, picking up a call would instantly hang up on the caller and the other portables would keep ringing.
Just today the phones were all showing offline in 3CX, including the Fanvil, restarting again fixed the issue.
The accounts were showing as "registering" in the base station.
I have also been checking the base station logs but find it hard to make sense of them, these three messages were repeated I'm guessing when the issue occurred.
This was over the weekend so I can't 100% confirm this is when the issue arose.
<131>Jul 3 20:49:30 sua [1424.1732]: SIP <3+error > [SIP] <AEM> code=0x04030202, message stun(tls) get mapped addr. ret=70004
<131>Jul 3 20:49:30 sua [1424.1732]: SIP <3+error > [SIP] <AEM> code=0x04030203, stun[1] retry fail. ret=-1, ka_interval=180
<131>Jul 3 20:49:38 sua [1424.1724]: SIP <3+error > [SIP] <AEM> code=0x04030204, message stun. status=370004
The base station is connected to 3CX via STUN, SIP alg is off on the Draytek 2133n.
I cannot see any logs under the event viewer or activity monitor that seem to correlate.
Everytime a restart has fixed the issue, I am thinking maybe something needs to be changed / added on the router but other sites with the same router have no issues.
Any help would be greatly appreciated.
Have you configured the devices the 3cx supported way for stun
If you use STUN, you need to carry out the steps in the link shared above.
You still have to do it even if some of the phones appear to work
Those will also stop working one day, it's ultimately a matter of time and luck.
The "variables" of your network environment can be controlled for if you deploy STUN correctly, or if that's too much work you could consider installing an SBC which bypasses all those problems and the need to play around with port forwards dissapears.
Reactions: JackT24
Thanks I will give this a try, otherwise I will install a SBC onsite.
Reactions: JohnS_3CX
Sure thing, let us know how it goes or if you need any more assistance/clarifications
DejanMDS
