Yealink W60B fails to register after VPN breaks and reconnects
So the reg interval is set to 120. Phone never re-connects after the interval. I tried updating the firmware to W60B-77.83.0.25.rom which was just released but having the same issue.
gbrown100...I am basically having the same symptoms. You can get into the base over the VPN but nothing will get it register unless you restart. I am going to run a wireshark as well so see what is going on with it.
@Jim Shaflucas did you manage to do a wireshark? I haven't been on site and they haven't had a connectivity drop since. If I get a spare moment I will go force the issue but my client is a seasonal business and are closed so it involves extra effort getting on site, shutting off alarms etc.
This is still an issue for me, I have had to remotely log in and reboot the base stations again... I can't believe only two of us are seeing it!
@Jim Shaflucas do you still have this issue?
Yes it is still an issue. I haven't done a wireshark yet though.
Manually config one of the phones/extensions and simulate a vpn disconnect and reconnect.
@3cxnub Mine are not over VPN and I know the internet had dropped between last time they went wrong and this time as I have the ISP data on line drops. To me right now it appears to be a time thing. It's pretty much 30 days since the last problem.
GothamUser
