Yealink W73P base station - supported / compatible?
kiwipython
Gold Partner
Hello, One of our salesmen has sold Yealink W73P DECT base stations to a new 3CX customer.
I cannot see that base in the drop down list when adding it to the system. Are these compatible or supported on 3CX?
Has anyone else used these and if so what model base did you specify in 3CX?
a WxxP is a pair of a H and a B (Headset and Base).
The W73P uses a W70B (and a W73H) which is listed.
Reactions: kiwipython
Hi SweetAction. That's good news. Thanks for the quick reply.
On the 3cx platform, I added an external dect phone and then introduced the w70B dect phone from the fxs/dect segment (direct sip-stun). Then I downloaded the Provisioning Link file and imported the Provisioning Link file as Yealink under Settings, and Configuration on the Yealink web page. the base station is trying to register but on the a 3cx side, I get IP blacklisted. and the phone becomes unregistered. how do I fix this problem thanks?
Erhan
Erhan
Check your extension settings here:
Mahlon
