Yeastar FXO and GSM Gateway Config Tutorials
arnie.cuenta
Forum User
Do you have any tutorials on how to configure FXO and GSM Gateway? And how to add the gateways in the 3CX Management Console?
These are not supported devices with 3CX (list of supported - https://www.3cx.com/support/) , so 3CX ill not have any tutorials.
Have you checked the manufacture to see if they have any documents.
Quick search on the web found this https://support.yeastar.com/hc/en-u...-How-to-Connect-Yeastar-TA-FXO-Gateway-to-3CX - there maybe more
Based on your experience what brand and Model of Gateways would you recommend for GSM Gateway , FXS Gateway and FXO Gateway that is supported by 3CX?
Here is the list...
https://www.3cx.com/voip-gateways/
BeroNet make a supported GSM Gateway.
Is it possible for Beronet GSM Gateways to view received messages to 3CX? Lets say I purchase 4 slot sim Beronet GSM Gateway. Each has different phone numbers. In case client will text either of the 4 SIM number, can it be viewed in the 3CX Management Console?
No
Wecare_ITA
