Zoho Call journaling not working
Shard Tech
I'm attempting to intergrate 3cx with Zoho, I've followed the tutorial and i can the tests come back with info, the web client triggers the records etc, but I cant seem to get the journaling working...
They created a custom field called Extension and I've duplicated that in the crm settings in 3cx however still nadda.
I found this little nugget when looking though the full verbos logs, ald they seem to be related, but not sure where the issue is:
Exception during call reporting: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason= - Content={"code":"INVALID_QUERY","details":{"reason":"the field is not available for search","api_name":"Extension"},"message":"invalid query formed","status":"error"}
Any help would be appreciated as I'm a bit stuck as the field exists so why its having issues who knows...
Probably the field exists but it's not accessible due to a permissions limitation. You need to ensure that the field is visible for the user that is configured from the 3CX console.
I'll double check tomorrow once the client is back, and then report findings.
Thank you
skander
