Zoho CRM Integrated with 3cx But Activity Not Working
Majdi-B
Hi every one,
I already Integrated zoho crm with 3cx this 1st step.
2nd step test client number from Settings / CRM Integration / Test button & the Number Match.
3rd step "Enable Call Journaling"
Test Outbound call & Inbound Call Activity Not Working.
Note: Query CRM for create contact "Working Well"
Need Help
Best Regards
Hi every one,
Need Help
Best Regards
Okay this is not clear.
Do you mean the Call Activity is not logged in Zoho?
If so, check that you have the Extension field configured for the matching of users.
Also, make sure the contact is matched when the call occurs. If no contact, no call reporting.
yes " the Call Activity is not logged in Zoho "
"check that you have the Extension field configured for the matching of users." i already follow the instruction for ZOHO CRM integration " https://www.3cx.com/docs/pbx-crm-integration-zoho/ " ( Extension_Number ).
"make sure the contact is matched when the call occurs. If no contact, no call reporting" the contact is matched.
Best Regards
Best Regards
Put the system in Verbose logging and run a test call. Then, go to Logs -> 3CXSystemServices.log and search for CRM. You'll see the requests/responses/errors that happened.
I will Try. Thanks
Best Regrads
I Search in "3CXSystemServices.log" didn't find "crm" or "requests/responses/errors"
Best Regards
Hi Frederick Marcoux,
Any Update ?
I will do some testing.
We are using Hubspot but have many customers on Zoho. None have that issue. We tested it on our ends, nothing either.
can you send me your system service log file by DM? I'll see if I can find something on your server.
make sure to enable Verbose and then restart all services so that it is taken into account everywhere.
OK Thanks Frederick.
Any Update?
Best Regards
