Probably you created the custom field with a different name, and then renamed it. Custom fields get the ID from the very first name you assign to it, and then even if you rename it, the ID remains unchanged. So you will need to figure out which is the field ID for this custom field.
The error you're getting means that the field "extension" doesn't exist on entity "Users". When you follow our
configuration guide for Call Journaling with Zoho, you need to create this custom field to store the extension number. When you do this in Zoho, the field ID is automatically set to the name you specify the very first time, replacing spaces with underscores. So for example, if you specify the field name as "Extension Number", the ID will be "Extension_Number". If you later change this field name to "Extension", the ID remains the same ("Extension_Number"). The ID will not change once you create the field, no matter how many times you rename the field. So you need to remember the initial name you specified in order to determine the actual ID.
If you can't figure out which is the correct ID, there is a way to find out. This is what you need to do:
1) Make a lookup test from the 3CX console > Settings > CRM Integration > Test button.
2) Go to the Logs tab, and you will see something like this:
Variable AccessToken set to 1000.43cb2fXXXXXXX774831dadbe92c944.5db34aXXXXXXXX27edXXX3554fce12
3) From a Command line window (cmd.exe) run the following command:
curl "https://www.zohoapis.eu/crm/v2/users?type=AllUsers" -X GET -H "Authorization: Zoho-oauthtoken 1000.43cb2fXXXXXXX774831dadbe92c944.5db34aXXXXXXXX27edXXX3554fce12"
(replacing the token at the end with the value taken from step 2).
NOTE: the URL could also start with
https://www.zohoapis.com depending on where the Zoho account is created (this should be the same than the value configured in the 3CX Console).
4) That will return a JSON with all the information of the user, including the custom field. For example, this is what I get here:
"users":[
"country":null,
"customize_info":{
"notes_desc":null,
"show_right_panel":null,
"bc_view":null,
"show_home":false,
"show_detail_view":true,
"unpin_recent_item":null
"role":{
"name":"CEO",
"id":"76741000000026968"
"signature":null,
"city":null,
"name_format":"Salutation,First Name,Last Name",
"language":"en_US",
"locale":"en_US",
"microsoft":false,
"personal_account":false,
"default_tab_group":"0",
"Isonline":false,
"Modified_By":{
"name":"eds",
"id":"76741000000077013"
"street":null,
"alias":null,
"theme":{
"normal_tab":{
"font_color":"#FFFFFF",
"background":"#222222"
"selected_tab":{
"new_background":null,
"background":"#F3F0EB",
"screen":"fixed",
"type":"default"
"id":"76741000000077013",
"state":null,
"fax":null,
"country_locale":"US",
"first_name":null,
"email":"
[email protected]",
"Reporting_To":null,
"decimal_separator":"en_AR",
"zip":null,
"created_time":"2017-12-18T10:35:30+02:00",
"website":null,
"Modified_Time":"2019-01-21T16:26:25+02:00",
"time_format":"hh:mm a",
"offset":10800000,
"profile":{
"name":"Administrator",
"id":"76741000000026972"
"mobile":null,
"last_name":"eds",
"time_zone":"Europe/Nicosia",
"created_by":{
"name":"eds",
"Extension_Number":"102",
"zuid":"20062680098",
"confirm":true,
"full_name":"eds",
"territories":[
"phone":null,
"dob":null,
"date_format":"MM/dd/yyyy",
"status":"active"
"country":null,
"role":{
"name":"Manager",
"id":"76741000000026970"
"city":null,
"language":"en_US",
"locale":"en_US",
"microsoft":false,
"Isonline":false,
"Modified_By":{
"name":"eds",
"street":null,
"alias":null,
"id":"76741000000244004",
"state":null,
"fax":null,
"first_name":null,
"email":"
[email protected]",
"zip":null,
"created_time":"2018-10-15T12:08:59+03:00",
"website":null,
"Modified_Time":"2019-04-04T09:22:40+03:00",
"offset":10800000,
"profile":{
"mobile":null,
"last_name":"ca",
"time_zone":"Asia/Nicosia",
"created_by":{
"name":"eds",
"Extension_Number":"100",
"zuid":"20064960092",
"confirm":true,
"full_name":"ca",
"territories":[
"phone":null,
"dob":null,
"status":"active"
"info":{
"per_page":200,
"count":2,
"page":1,
"more_records":false
So, you can search for your extension number in the returned JSON, and identify the field name, as highlighted in bold above.
Once you identify the ID of this field, you need to configure exactly that value in the 3CX console.
Hope the information helps.
Kind regards.
