zoho crm template
pgarcia
Good morning everyone
I just deleted template for zoho crm integration, what can i do in order to get it back
Thanks in advance
You can get the templates from other systems from under the location of the template C:\ProgramData\3CX\Instance1\Data\Http\Templates\crm, in windows and /var/lib/3cxpbx/Instance1/Data/Http/Templates/crm, for Linux and press Add under the management console > Settings > CRM tab and upload the template back, for your convenience you can find it attached.
Or simply open the "Updates Available" collapse in the Settings > CRM, select Zoho and click Download.
Reactions: ClsVip
Does this work for you, as it does not work for me :)
It always did for us. If the template is deleted, refresh the page and it will appear in the list of available updates in the CRM page. Not on the Updates page.
Reactions: ClsVip
Thanks ConceptsWeb, problem solved!!!!.
