ZOHO Integration, help.
ostrov65
No registration of incoming and outgoing calls.
ZOHO
10040
3cx
10041
3cxSystemService.log
2019/03/30 15:46:15.050|624|0036|Erro|Exception during call reporting: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason= - Content={"code":"INVALID_QUERY","details":{"reason":"the field is not available for search","api_name":"Extension_number"},"message":"invalid query formed","status":"error"}
What did I do wrong?
I wanted to add to the above that when an incoming call comes from a new contact, a lead is created. But if this contact calls again, then nothing changes in the activity, it is empty.
Please remove the field with visible name "Extension_number". Just use "Extension number", and then the field ID will be "Extension_number" (replacing the space with an underscore).
The error is not complaining about an invalid field name. It's just saying that "the field is not available for search". That means that Zoho somehow can't use that field when it tries to search for the agent having that extension number. Please check if your custom field has some configuration to avoid searching by that field.
I did everything as you said, but nothing has changed. Activity is empty, no call logging. What do you mean by "custom field has some configuration"? I created and deleted this field several times with default settings.
10067
10068
10069
10070
If you deleted and re-created the field several times, that will explain the issue. When you delete the field, the ID is taken by Zoho, and a new field created with the same name will have a different ID. So, "Extension_number" is the ID for a deleted field, and can't be used anymore. In order to identify the ID of this field, you need to use a REST API call that retrieves all the fields and IDs. This is a complex operation for non technical users, so a simpler approach will be creating a field, but using a different name. For example:
Agent Extension Number
Then the ID will become:
Agent_Extension_Number
Please note that the case is important. Please try creating this new field, and let us know if that fixes the issue.
Reactions: ostrov65
Thank you, everything worked. :)
Lack of this information cost me 3 sleepless nights :eek:
Reactions: edossantos
Thanks for your feedback, we will improve the documentation.
skander
