- Joined
- Mar 26, 2015
- Messages
- 16
- Reaction score
- 5
I've set up the Zoho CRM Integration by following the instructions here: https://www.3cx.com/docs/pbx-crm-integration-zoho/. Everything on both 3CX and the Zoho side looks to be set up correctly. I didn't have any issues or error from the setup but it's not working as it should. It's like it's not integrated. There is no pop up on incoming calls and outbound calls aren't being logged. The API name looks to be fine. When I press the "Test" button in the CRM Provider Configuration in 3CX I receive this error: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason= - Content={"code":"INVALID_MODULE","details":{},"message":"the module name given seems to be invalid","status":"error"}. I've tried refreshing the token, restarting the services, restarting the cloud server. Zoho support stated that everything looked correct on their end but it's not communicating with 3CX. Has anyone had this issue or know what might be causing it? Also our 3CX is on version 16.0.910
